TwinTurbo.NET: Nissan 300ZX forum - if the shifter is in 'neutral' then its not in gear..
apostrophe28
on April 07, 2008 at 8:50 PM
now she wont start
posted by forced1(nyc)
on April 07, 2008 at 02:00 PM
even w a blown clutch you can still pull it back into neutral w a lil force. did u check the obvious connections? do u have gas? did u reconnect anything that you disconnected?
now she wont start
forced1(nyc)
14:00:28 04/07/08
Did you disconnect the battery in between?
Audioquest
14:18:48 04/07/08
it cranks, but wont turn over. like i said before, sounds
forced1(nyc)
17:26:45 04/07/08
if the shifter is in 'neutral' then its not in gear.. -
apostrophe28
20:50:15 04/07/08
sounds like your starter is not engaging the flywheel
Ashman2k2
23:31:49 04/07/08
but the fan is moving, meaning the main pulley is turning
forced1(nyc)
02:56:57 04/08/08
oh gee, are you saying it sounds like the engine has no
Ashman2k2
14:51:35 04/08/08
